leaking clio
  1.5 dci 65 extreme clio
I have a renault clio 1.5 dci 65 extreme which has started to leak in the passenger footwell i cannot find where the leak is coming from i heard it may be sunroof but seals seem fine i have also read that sunroofs have drainage holes that could get blocked where are they? and how do i get to them i have no idea how to remove the sunroof door seals are ok except for some water inside passenger door the smell is getting bad now like rotting veg! this only happens during heavy down pours can someone help me please. also there is water running over inside trim on bottom of door
Take the sunroof out and clean it all up and you'll fine where the holes should be else you have to strip it and down areplace the seals.
But if its in the fottwell check the drain seals under the scuttle panel and also the door seals plus air con filter if you have it for blockups.
