182FF
As above really. Put some LED lamps in the stop/tail and because they don't use as much power i'm assuming the cruise control checks the loads on the lamps and if not right then disables cruise control (about right?)
Question is, what circuit does it check, tail or stop? The lamps came with some resistors i can put in line to create a load but i don't know which circuit they are needed on.
Thanks for any info
Thanks for any info
