Ok cool fair enough. If that is the case, and I buy a lens which needs calibration, the manufacturer will do this free of charge I presume?
I've not tried to use it at a concert though like yourself. I did hear that the f4L (non IS) is the sharpest of the group of those lenses? (f4L IS and the 2.8 IS) Not sure how true it is.
As for f11 at 10mm, you've got pretty much infinite focus wherever you set your focus to.
Your much less likely to notice a focusing issue on a wide angle lens. Typically your shooting wide at distant objects, so DOF is emphasised as much as shooting F2.8 200mm @ 3m.
10 - 22 is an epic epic epic lens in the right situation. If you cant get close to your subject you'll find that photos just look dull and everything just looks lost in the frame? Depends on your style of shooting as always tbh.
