Hello, first time using the pc today. Ive got some light swirls and holograms. Should i be ok using sfx 2 polish on sfx 2 pad and then to follow up with srp on the sfx 3 pad?
didnt work very well at all, even after multiple passes. that renault paint seems to be hard stuff. think ill have to order some #83 this week and try it at the weekend. would i be best to use that on the sfx2 pad first then if its not working well move to a sfx1?
Chances are it will need a light cut pad but ideally you should try it on the polishing pad first. Not a big #83 fan and don't use it myself these days but a lot of others do so will hopefully give you some more advice on it.
