Lighting problem
I wondered if anyone could shed any light into the problem i'm having (pun intended ;))
Today i had some new side light bulbs to try so i went ahead and started to change them. The passenger side went fine worked straight off. I took out the drivers side, put in the new bulb and nothing came on, tried it the other way around, still nothing. I put in the bulb i took out and nothing! I've tried having a little play with the wires and nothing still comes on.
I don't know if this is a coincidence or related but my drivers side rear light is also out now but when i break that part lights up. I tried a new bulb and its still the same. Now i've not had chance to look at the wires on them as i know they are sometimes problematic. Could it be linked or is it just by chance? I say this as the other day i changed my indicator bulbs and i could have caused it to stop working on the back then.
Cheers.
Check the earths on your head lights in the boot I'll recon there usless just clean them uo and try again.
