lights
Just wanted to know if anyone could help me ( well the other half) he's got a 1.2 16v clio and dont know if anyone else has had this problem but wenever it remotley gets dark his lights cum on even in the middle of the day.... sumtimes full beam too, is there anyway of turning this off? thanx :)
Yeah, it's the auto light function. Turn ignition key all the way round, but don't start engine. Swich lights on and off (twice I think) then this should switch the function off. You (he) will then have to switch his lights on/off manually.
Its the automatic lights, i think you can turn auto lights off,by turning the ignition key to the first click when stationary, then turning your lights on and off 3 times, or something like that, then you might hear a beep, they should be then de activated. Or ask your dealer to make sure. I'd leave them on though as its quite helpful in the winter!
Mike
stacy said:
so if you did that then to turn em off, how do you switch the function bak on? repeat the same thing?:)
Yeah I think so, as i did this when i first had a clio, put it back on after as i missed the lazyness!
