List of random questions that I NEED HELP with
Car  E36 328
  1. How much would a wheel bearing be on my 1.4 92 clio?
  2. What happens if i dont replace my worn wheel bearing? Will the wheel come off or just seize up?
  3. How much are gearbox mounts?
  4. What happens if i dont replace the gearbox mounts? Will the gearbox fall out or will it just seize up?
  5. I had a new driveshaft fitted today and since i had picked it up its had a lumpy idle like a muthafucka!! wats up with that?
  6. I snapped a CV joint friday nite, and wen i took it to the garage they said i need a new driveshaft, but the AA guy didnt say anythin about this, hav i been done up the arse by the t***s at my local garage?
Thanks for all your help
1) Think my RS ones were about 30-40 per bearing
2) It will get louder and louder and louder until it drives you insane but your wheel wont fall off.
3) Not sure for the 1.4
4) The mount will allow movement of the engine and start to nacker the other mounts
5) Dunno...
6) No the CV joint can cause the drive shaft to pop out or kill your box in a worst case.
[*]How much would a wheel bearing be on my 1.4 92 clio?
The poart alone say £25 at a motor factor then say 1 .5 hours labout to fit or do it yourself and get a garage to press the bearing in for £10.
[*]What happens if i dont replace my worn wheel bearing? Will the wheel come off or just seize up?
It will get noiser and noiser wheel will wobble and in time with wrech the hub so you'd need a new hub.
[*]How much are gearbox mounts?
£40 or so for the dogbone mount.
[*]What happens if i dont replace the gearbox mounts? Will the gearbox fall out or will it just seize up?
Will fail over time the engine will shake about more and more in the end would damage the main mounting bolts.
[*]I had a new driveshaft fitted today and since i had picked it up its had a lumpy idle like a muthaf**ka!! wats up with that?
Sounds like they've knocked a sensor or not done somehting up maybe engine mount.
[*]I snapped a CV joint friday nite, and wen i took it to the garage they said i need a new driveshaft, but the AA guy didnt say anythin about this, hav i been done up the arse by the tw*ts at my local garage?
might as well change the shaft I don't rate the DIY fix ones.
