would that happen ive wheelspun fast?Quote: Originally posted by CraigM on 01 January 2004
It is probably the dog bone mount (was on mine) only about £10 from renault and only takes about 10 mins to change - only 2 bolts.
The problem with the mounts is they are too flimsy and the large mounting hole stretches and becomes slightly oval. You can see it on the one I removed from my car against the new mount: http://www.mcmillan-uk.com/clio/dogmount.jpgwww.mcmillan-uk.com/clio/dogmount.jpg
Quote: Originally posted by CraigM on 03 January 2004
Yup, that mount gets pulled and pushed every time you accelerate - if you accelerate hard or wheelspin then there is a lot of force going on it which in time stretches it.
Does your gear lever almost rip your hand off when you change gear, or does it jump out of first when accelerating very hard? Mine did this, but it improved once I fitted a new mount - but that needs changed again.
Try opening the garage door before you take off Rich!Quote: Originally posted by I2ich16v- on 03 January 2004
hehe i sometimes get a loud bang ! when i change gear fast![]()
