low rev missfire
  clio 182
hi guys got a missfire / stutter between 1k and 2k revs all fine at higher revs
i have looked at the other threads and have already changed the coilpack, leads, spark plugs and lambda sensor
there's no lights on the dash either ive checked for a manifold leak found nothing.
if it were an injector it would come up with clip right?
any other ideas?
Gus
  182Turbo,DCi90
Everything points to injectors considering what you have replaced already. I dont know what clip would identify in terms of injectors but it might be worth your while having the injectors cleaned which would cost £50ish and take 3-4 days or buy new ones (make sure they are genuine ones , search the forums on this thoroughly as one brand has issues when starting the car) for £130 .
I am guessing that perhaps the spray pattern might be affected on one injector. Changing injectors makes a nice noticeable difference.
  Monaco 172 + mk1 RSi
I've had it plugged in to clip, no real faults but it's sorted now lol
Only code is a lambda heater circuit code on post cat lambda
Misfires gone now!? Mystery!
