Clio Trophy
My code reader has identified a misfire on cylinder 3 but curious if the symptoms here can point towards anything in particular before I take it to a garage-
Any likely culprits with those particular symptoms?
- Revs with no issue when in neutral only (no load)
- Obviously misfires when trying to accelerate in any gear at low revs- happens from cold and once up to temperature
- Once above approx. 3000 RPM there is no obvious misfire and the car accelerates as normal in any gear. Can rev all the way to the limiter with no issue.
