Lowering car
If I wanted to lower the car with springs, do I need anything else? Also, what are the best springs to look for? Cheers
eibach are good but wont give u the drop they say. depends how low u want to go as to wether u will need new shocks.
i would try and get shocks aswell mate, i lowered my clio on springs only, and the standard shocks soon went anyway.
my mate lowered his 106 on springs only, soon his shocks/driveshafts/torsion bar etc were all needing replaced!
If the lower ride height caused that it wont make a s***s bit of difference if he dropped it 40mm on springs or 40mm on springs and shocks. If the 40mm change effects the position of balljoints driveshafts etc enough to f**k things up then its the same no matter what kit has dropped it that far. As for the torsion bar that may be down to who lowered it. On a car with a torsion bar fitted the lowering springs go on the front and you move the torsion bar a couple of splines to match the height on the rear. There are no springs at the back!
  Clio Dynamique 1.2 16v
Was thinking about dropping mine too..only wanted to drop bout 40 though..dont wanna nacker my arches..bin told to use apex though..
