Major Misfire - Plugs
  Clio 1.2
Hi guys, I have a huge problem with a misfire, last night as I pulled onto my drive I must have been running on 1 cylinder as I there wasn't even enough power to get on my drive.
On the insides of the HT leads there is rubber things that sit around the plug 2 of these have come out and are now stuck around the plug and I cant get a socket over the plug.
Any ideas on how to get the rubber out?
MicKPM
ClioSport Trader
  Clio16v/Zoe Z.E.50
Thought so... I use the plug removal tool with a hammer to gently tap it over the rubber but be carefull as you can break the plug if you're not careful.
MicKPM
ClioSport Trader
  Clio16v/Zoe Z.E.50
The spark plug removal tool... you'll struggle to get a standard plug socket in those holes!
MicKPM
ClioSport Trader
  Clio16v/Zoe Z.E.50
Just take the cap out which grabs the plug... you won't need it and it'll stop the tool going on properly.
