manifold to cat sealing kit
Is it the same as the 172 kit?? Ive just changed my cat on my 172 and could show you what order it goes in.
It is yep, 100% sure it is.It's the springy bolts.
Just want to make sure i get it right as the one on there is mullered and might not be on properly.
This will be hard to explain. The 2 silver cylinder caps and the bolts go on the manifild end, the end of the bolts are housed in the caps. The caps slot in the holes at the end of the manifold facing the engine. The springs go at the cat end, and the brass coloured caps go on the end of the spring all held on by the little bolts. IIRC there are 2 types of 2 different washers and I cant remeber where these go without looking but Im sure they are at the cat end.
The round gasket ring should fit nicely in the cat.
^Thats what I was trying to say. In the last pic I think the silver washer should be on the end touching the cat?
Cant really go wrong. The bung fits into the manifold only one way and the main washer is recessed to fit (flat edge)
