mastercylinder f**ked or no?
hi guys
scoffs been having problems with bleeding my brakes, but he loosened the pipes going into the abs pump then pumped the pedals and theres barely any fluid coming out
he thinks the seals could be away, would that be right?
  Clio T 314hp c43 AMG
You may have turned the seals inside out putting the brake pedal to the floor, so possibly new master cylinder.
id try and use a proper fluid bleeder, even a gunson easy bleed.
