Maxogen fitment
Re: Maogen fitment
Its the tube that goes to the AV
Block it off at the plenum, The kit should have a stopper in it
Cue
  182 Trophy #274
Re: Maogen fitment
ahhh so you remove the entire tube..... instructions didn't mention it... i have a little stopper, looks a bit small to fit the plenium but i'll give it a go.
Steve
  ST3 8.5
Re: Maogen fitment
Told you on CT yesterday what the bung was for!!
Just remove it all, bag & seal the plug end.
Cue
  182 Trophy #274
the bung is no where near large enough though in diameter to plug the end of the plenium, it's about 1.5mm across, it needs to be around 3mm to fit where the tube is......
i've just used insulation to plug the end and secure it to other tubes.
Steve
  ST3 8.5
What planet are you on??
It covers where that pipe is in your first photo!
Your turning a 45 min job into a week?
Cue
  182 Trophy #274
all done, test drive has revealed a just over 1 second improvement on my 20-100 time! was a rough time done a wrist watch but hell that's a reduction of a 10th... feels a lot more responsive, noise has become a bit more 'growly' but it's hitting the change up points a lot quicker....
next is a remap on the 24k service. About a month off, will get RR figures through to see what all the improvements have made to BHP. hoping for close if not just on 200bhp.
Re: Maogen fitment
it does actually say in the instructions to block that off with the supplied grommet, mate.
Cue
  182 Trophy #274
i didn't have the blocker though, or thought i didn't, found it loose in the bottom of the green box, this it must have fallen out when i opened the package as it can't have got in there any other way.
Didn't see the part in the instructions where it said to block it off at the plenium either, but then i'm not great at reading instruction..... get bored and just get on with it.
Ha ha, I used to be like that too mate
