Megane F7R
  Megane mk1 f7r
Hi all.. sorry not a clio but I was just wanting some advice, I’m running a f7r in my mk1 megane.. in the stages of a turbo build, I was wondering what the best gearbox is to use that will handle the extra boost?
16v_paddy
  Valvers & 172 Cup
Depends on how much boost/power and if it's going to be used more on road or track tbh
Some people prefer to use JC5 089 from the ph1 172 as the gear ratios are more suited to it - still made of the same French chocolate as all the other boxes so not really the most suitable option for big power.
For big power and reliability you want 1 of the VW gearboxes -I have no idea what the codes are though- it's a fairly common conversion so there's a decent amount of people about that know what's what. Plus the front end of the MK1 Mégane is near as dammit the same as a MK2 Clio so the information on how to convert in a Clio will mostly still apply for the Mégane
  Megane mk1 f7r
For big power and reliability you want 1 of the VW gearboxes -I have no idea what the codes are though- it's a fairly common conversion so there's a decent amount of people about that know what's what. Plus the front end of the MK1 Mégane is near as dammit the same as a MK2 Clio so the information on how to convert in a Clio will mostly still apply for you
hi mate thanks for your reply, yeah iv been doing some research on the vag gearboxes and I think it’s a 02m code box I need with the adaption plate and flywheel. Just need some more advice on this now
