Megane mk1 Coupe 2.0 16v suspension
  Clio IV 0,9 Tce
Hi Guys
I am contemplating buying a Megane Coupe F7R. I’ve been looking at suspension for it. I want coilovers, and I want something good. Something like Bilstein B14. However I cannot find anything, so my question is, will it fit from at Clio 1 or 2. Any help would be appreciated.
Kind regards
Dennis
Jaff.
Discontinued, you won’t find F7R coilovers new unless you ask specifically for a 1 off set.
or buy second hand.
clio stuff will fit, can’t remember which but the hub bolt spacing is critical, there are 2 different spacing iirc.
top mounts will not fit and you will need to use standard F7R ones unless you want to modify the car to make something fit or make custom top mounts
Jaff.
Cheers mate @Jaff. How about the rear will Clio shocks also fit here?
maybe, you’d have to get the shock lengths. But it’s a different setup anyway
Trailing arm and tortion bar on megane
Trailing arm and spring setup on clio
