menzerna products
  clio sport cup 172
is there anyone can give me some advice on how to use 1,MENZERNA FINAL FINISH 2, MENZERNA INTENSIVE POLISH. getting a polisher after christmas,new to this detailing, THANKS
Gaz_
  Extreme mode
what polisher you using matey? I have the exact combo, and really rate it :)
Gaz_
  Extreme mode
Well i use the PC, (porter cable) as probably most do on here. I tend to use the Intensive polish on the sonus yellow bad, as this has more 'bite' for swirl marks etc. One i've done that, i follow up with Final finish on a sonus white pad. Gives fantastic results on black, which is probably the hardest colour to get defect free.
Search for PC guides etc on here, should bring up some useful threads.
I got a couple of menzerna polishing pads not so long back and i wasnt really impressed with them just feel a bit tacky and quite aggressive i really rate the sonus pads though :)
Not heard bad things about the megs pads either never used them myself - expensive
  106 GTi
The Menzerna polishing pads are superb, one of my fave. discovery's. They provide almost light cut pad correctional abilitys but still allow you to finish down to a wax ready finish.
Key to the Menzerna's is the same as any polish, make sure you work them until they have broken down properly the later formulations of Intensive Polish have very long work times - you may find them a pain in the cold weather.
  Fiat Coupe 20vt
Slightly biased but I really do rate the menzerna pads. Being 5" on a PC they give it that bit extra. They don't bog down as much as the larger pads either.
You guys know a lot more than me for sure so your obviously right i just dont really like them compared to the sonus ones, bear in mind my paintwork is in good conditiion so its probably is a bit aggressive for it
  106 GTi
You need to use it once to break it in so to speak, brand new it feels very firm, after one use it softens up. It is a great pad for in good shape paint with Menzerna Final Finish it does a superb job.
