I didnt need to worry about short skirts !!
What I ment to say is it was "more fun in the wet" as you could play with the back end quite alot.  It was always supprising at how quickly it came back under control as soon as you came off the gas, it snapped back in line very quickly and you could plant the pedal back into the floor straight away (you had to be quick comming off the gas though !).
The cup is a bit more unforgiving when the front end goes in the wet, under power, on a corner and you carry a little too much speed into the corner.  But I must add you do have to drive a little silly to do it and it is far harder to get it back in line then.
I used to enjoy pushing the MGF in the wet to make the back end go as it recovered so well, this I do miss in the cup.
