How many miles hve you done in it? Mine did this when I reset the trip untill I done a few miles so it could work out an average mpg to work out what's left
Mine shows ---- just after my fuel light goes on (stupid really as that's when you need it most!!) usually about a gallon of fuel left when this happens to me. Sure you don't just need to fill up ;-)
Try what Pastieman said.
But as said, if your orange petrol light is on, it won't show anything.
Probably a good thing or people would be using it till the car told them they had a mile left. Which would be wrong as its not that accurate.
Then Renault would be getting complaint after complaint.
Is there a solution to all the stats re-setting every time the car is locked? My old 182 used to keep the mpg etc until I reset but the 172's keep going back to 0. I can live with it but if there's a way of sorting it I may as well give it a try.
Once the fuel warning light is on the computer doesn't tell you how many miles to fill up. Usually it's when 2 gallons are left in the tank which equates to around 60 to 65 miles. My Trafic does the same thing and the Nissan I had previous to the Trafic was the same trip computer. As someone else said if you hold the button in and switch the ignition on it sends the instruments into test mode. Keep pressing the button and it goes through all the modes and tells you how many litres of fuel are in the tank as well as the CO reading if you start the engine.
adam1 probably your battery needs replacing mate. i looked around on here and thats the general reason, got a new battery and it never re-sets itself anymore!
my light goes on at 40 miles, dash then goes down to 35 and then just goes to - - -
