Having a few running issues with the clio.
It has developed an intermittent misfire which seems to be getting worse. It started with the engine light coming on and flashing but then going off and now the engine light is staying on as a solid light. The car also has a rough idle.
I've swapped the coil pack as had one lying around but that's not made any difference.
The plugs have recently been changed but the previous owner went Bosch so I've ordered some NGK ones from g172 anyway. I'm thinking of swapping the leads as well while I'm at it.
I've searched and there are several threads but just wondered if anyone has had similar symptoms and what the fix was.
