Misfire doing my head in!
Car  MG ZR x2, Polo, CTR
After any suggestions as to how to solve my misfire.
Showing as fault code P0300 and EML is flashing.
So far I have tried:
Fresh fuel (car was sat a while, so better safe than sorry)
New plugs (NGK PRF6E from G172)
New coil pack
New cat and fittings
New crank sensor
aside new leads (going to triple check the connections / firing order tonight before I order more parts)
I'm running out of ideas.
HELP!!
as in, injectors are shot, possible loose/poor connection or just run some injector cleaner through the system?
i'll add those to tonights list of jobs
Disconnect one at a time to identify which cylinder is misfiring. Obvs reconnect each one before disconnecting the next and when you pull one and the engine note doesn`t change you have found your knackered bit. You can either pull the power plug from each injector or remove the HT lead. Your just trying to work out which cylinder. Then yeah I guess check the resistance but mine was obvs a knackered injector as I had changed leads and Sparks so just bought a new one when i had identified which cylinder/injector it was. Hope that helps fella or should I say bloke.
Update:
all sorted, no idea what the problem was, but its now solved with no additional parts.
I removed the new coilpack,
unbolted the plenum
removed all ht leads.
removed all plugs
disconnected and removed all injectors
degreased all injectors.
re-assembled
worked spot on!
