misfire from cold(1.2 16V)
  54 astravan 1.7tdci
someone with knowledge please help.when starting for the first timein a few hours it coughs and splutters.changed spark plugs airfilter and oil as it needed a service.but the problem remains.can't afford to take it to a garage at the mo.the cars a 03 dynamique.could also smell fuel when started today.could it need a fuel filter? cos i run low on petrol quite a bit.probs gettin worse arghh.
  54 astravan 1.7tdci
Coil pack? Won't be the fuel filter, its got a 150k lifespan.
thought when the coil pack went a light came on on the dash.i had one done when the car was quite young.have u experienced it before?
£50 aren't they!
icant afford to change it and find out thats not it. thanks for the help anyway.
Da
  Less
The coilpacks can let moisture in causing the miss-fire. As for showing on the dash I'm not 100% either way. Try disconnecting the HT leads 1 at a time and see if it makes any difference, remembering the order of them though!
TDC sensor is another possibility and it's about £30 from dealers I believe. Plenty of threads on here about it.
Someone I know had a 1.2 16v with miss-fire and shuddering problems. It was eventually diagnosed as the upstream oxygen sensor which set them back close to £200 at the dealers.
Check the carbon canister miaybe its bust.
Check the temperatrue sesnor and the TDC sesnor one of them might have failed easily also check/clean the throttle body.
Fuel filter as said is good for 150k.
£50 aren't they!
Doesn't come on the light.
Coil packs are £30 or so easch a set is £120 in theory since the 1.2 uses seperate ones.
