Inferno 182 & Saxo
Wonder if anyone can shed some light on a strange little misfire I’ve got on my 182. When started from stone cold at around 1500rpm ish (with the lightest sniff on the throttle) I get a misfire when clears after maybe 30 seconds or so once the engine has a little heat in it. The misfire doesn’t come back either until the car is started up from stone cold again.
Plugs are relatively new (6 months old or so and under 2k miles on them)
I’ve done the obligatory leads and coil pack as I had them on the shelf and I’d been meaning to change them as the leads and coil were original 15 odd year old items.
Lambdas are knocking on a bit in age now, think I replaced the pre cat one about 7 years ago.
Injectors whilst they are all original all resistance check at around 15.3-6 ohms.
Not getting any fault codes what so ever so I guess im left with looking at live data to see what is going on?
Coolant temperature readings I’ve had a look via my cheapo diagnostics and seem to be about what you’d expect to see though I’ve got a new sensor on the shelf to fit if need be.
Mpg is fine, other than this issue the car drives just fine and pulls well etc.
