Hi there, i have just bought a 172 02 plate clio, i checked the plugs when i bought it as it was a bit lumpy on idel, 2 were quite worn which i noted to get some new ones in the next week or so. Anyway went to put my foot down couple of days later and one cylinder cut out, engine management light started flashing so i limped it home. Changed the plugs for bosch super fours the next morning and it was fine, still slightly lumpy on tick over but much better. Anyways same happend today, took idividual leads off the coil and found its a misfire in cylinder one. So where do i go from here?
i thought a coil just gave up the ghost not became tempremental?
ht leads are all visibly fine.
oh and is it true these should only be run on iridium plugs? (only got told today?
any help would be great
