Misfire with fault code
Car  pb ph2 172
3024Injection valve cylinder two
Open circuit / short circuit
also I've removed the plugs and cylinder 2's plug is black
I had similar to this on my 1.2 turned out was the injector
mine was intermittent at first then it was constant
Changed all four injectors to ones from a 182
still miss firing so I e changed plugs coil pack etc to no avail
only thing that's changed is now all 4 plugs get covered with black soot
and black smoke comes out of the exhaust
