MK2 172 FF
I have an annoying misfire. Its ok above approx 2.8k revs but anything below that and on idle it misses.
Ive changed the plugs for some proper NGK ones
Tried a new coil pack and HT leads
Run it on the RS Tuner and it comes up with nothing
Also replaced front lambda sensor aswell
been running it on 98 RON fuel and its made no difference
I had an issue with the CAT melting due to a faulty lambda sensor so the CAT pipe is there but has no cat inside. ie, DIY de-cat as i didnt want to pay for a new CAT at the time. I also have a Henk remap, the car performance does alter when i swap maps from the New Henk one to the old one and to the new Renault map they put on but the misfire is still there.
Any ideas?
thanks
Any ideas?
thanks
