Misfiring/ Juddering 2nd-5th gear, only 1-2k revs.
Car  Clio 172 2001 ph1
Hi Guys,
As the title says, my 172 misfires/ judders on accelerating but only from 1-2k revs. After that it pulls fine and doesnt miss a beat. Also the problem mainly happens in 3rd - 5th gear when accelerating, but if you accelerate slowly in 2nd it is noticeable.
Any ideas as to what would cause it? No fault codes logged on the ECU, i have checked. Last two times I have done a motorway run the service light and airbag light have come on for 10 mins or so then gone off, and still no fault codes logged (although knowing French electrics this may have nothing to do with the above running problem).
Any help is appreciated.
