Missfire 172
  Ph 1 172
So the 172 still has a missfire wondering what to try next so far
i have pulled a ht lead off 1 at a time whilst running and this makes a change to the way the engine runs so I know there is nothing wrong with the coil pack, leads, injectors from what I gather.
i had a fault with the lambda sensor (its a phase 1) so only have one sensor changed that, and it sorted itself out for a couple of weeks but now it has come back worse! So would you check the lambda sensor again or do you think it would be pointing at a sensors fault?
TheEvilGiraffe
South East - Essex
Pulled all the plugs out ?
50p says it'll be cyl 3 (3rd from belts) as that's normally the culpret.
Assume it only misses under load ? Hence no change when you take a lead off..
  Ph 1 172
Belts done last year by a specialist who is highly recommended on here.
yeah mainly only misses underload, ill check cyl 3 as well thanks for the info.
