Missfire At Low Revs
All running problems on the 182 are common I'd get it to a delaership if its under warnetly otherwise coils failing are getting common as it gets cold again.
yeah could be coils ive had it to a garage today not renault cos my warranty is out and they said it was not showing the fault on the computer but they said plugs or coil could be knackered but i cant believe the plugs are gone after only 15.000 miles the fault is occuring at 2.500 revs and below after that it clears but feels like its gonna stall at low revs its annoying cheers for suggestion
I had both plugs and leads changed on my 182 due to water corrosion in the plugs havent a clue how this happened but only on 24k miles now.
god thats shockin and ive just changed the coil pack on mine and it has not cured the problem better change the plugs n leads bugger
