Missing fault
Car  2002 172
Whe n you are excelorating even gently sometimes it will kind of get stuck in the revs and misfire really badly. if You keep your foot down it will shoot off after a while. when this happens it gives a lambda sensor fault code.
However i've change both lambda sensors and done a service including leads.
Anybody have any idea what could be causing this?
i've tried coil pack and it's still doing the same thing. Anyone got any idea's? It's already ha sparks and leads
injector maybe - I've been having the same problem with my 172 Cup & its booked in on Wednesday to check the injectors as everything else aprt from coil pack has been done.
