Missing headlamp washer ball.
Fletcher
Hello everyone.
I have just noticed that i've lost the right headlamp washer ball, i was wondering
a] Does anybody have a part number for one?
b] How easy are they to fit, do they just clip back in place?
c] How much are they?
Cheers Fletcher.
  Ford Fiesta
common fault with these cars, and presume other renaults with same washers. Either ball falls out or like whats happened to mine they just start leaking and need replacing. To do job properly you need bumper off, but most dealers will just bend it back to fit a ne wone.
About £7 for a new unit, or you can bodge it and try glueing a new ball in from another unit. But you can't just buy the ball.
You need one though or water will leak out and you wont have washers, = failure for MOT.
I can get part number if you need it..
  Ford Fiesta
no probs then if its under warranty. Took about 1/2 to do my first one, if they change the whole unit which they should. They are cheap enough it's just some dont seem to last long.
Seems to happen more in winter, cold and frost gets to them. Could do with some little headlight washer socks ;)
