mk 2 door card removal
hi, ive searced the forums, but could not find anything on how to remove the door card. just wondering how easy it is before i start ripping it to peices? its a 2003 1.2 16v btw
ye, its realy easy to do. i think its just remove the door handle (1screw i think) and 1 screw for the bit with the electric window switch. Theres a few along the bottom, and then you have to remove the speaker. the cover just pops off, then unscrew. Im sure you gota take another plastic bit off aswell, the bit that goes up the side of the window, that just pulls off. I thinks thats all it is, im sure somebody on here knows exactly tho. hope this helps
Struggler
  Ph1 track 172
jst undo every screw and pull,
on my ph1 theres 3 at the bottom,
1 in the door open handle,
1 in the other door handle,
take the speakers and window switches out
and the bit of trim at the top by the mirror
and it comes off,
however if its never been off before you may find its been masticed on aswell.
