Ok i saw on here a couple of days ago that someone was having trouble with there central locking only working if and when it wants to and some times not at all and was talking about changing the whole circuit board and key fob, i read they had a water leak and i also had this and my central locking was playing up. So i had a butchers i took out the circuit board and it was badly corroded so i took a soft copper wire brush and gently cleaned all the corrosion away.
Replaced the circuit board into the wiring loom and tryed it, now i can unlock my car from about 3-4 meters away just like new, rarther than trying to do it when the fob is pressed up against the window in frustration
I would post in the other thread but i cannot seem to find the previous thread.
Good Luck
Good Luck
