mk2 ph 1 ph 2
  golf
I no the exterior is slightly different but, is the suspension the same and the rest of the running gear?
cheers
The parts are the same size etc so interchangable* but there different as such.
* front dampers etc can have diffferent hub bolt spacing it depends.
no the wiring is different , lights will fit easy enough .
you can wire the lights easy enough to work
  MINI Cooper S
Yeah rear lights are easy job, just make sure theyre wired up right. and yes only one fog will work!
