MK2 PH1 Clio Fitting MK2 PH2 Dash
  GOLF GT TDI
I have thought about doing this alot and just wondering if its possible to fit the MK2 PH2 Full dash into my MK2 PH1 Clio, i know is have to basically change the whole front dash, but surly it cant be that hard??
Has
  RS 182 - Black Gold
erm it can be done...
top dash needed
lower dash needed as well
airbags different?
as well as switches etc....
clocks?
be long and tedious job but has/can be done.
  Lots of Alfas
Ive seen it done on mk2ph1s with a 172 conversion try finding someone with the conversion and ask them for advice. As above you will also need new front door cards as the old ones wont close with the newer dash i think.
  Mégane RS
yup, prima racing done it to there 172ph1, changed outside and inside to ph2 iirc
  Clio 197
You have to change everythings, what Has just said:)
top dash needed
airbags different - yes
clocks - yes
Door cards
speedo
stalk for airbag & horn for ph2
wires plugs are may be different
there more things you need.
Just buy a mk2 ph2 clio
  Monaco Blue Mk2
Need absoloutley everything. Lots of work. Can be done though, not particularly difficult, just a bit daunting and tedius.
