would this fit on to my mk2 ph1 without modification? if not, how easy would it be to do?
J Jaypee Aug 16, 2005 #1 would this fit on to my mk2 ph1 without modification? if not, how easy would it be to do?
Da Less Aug 16, 2005 #3 requires modifications to the mounting brackets afaik. The actual physical size/shape of the bumper is the same.
J Jaypee Aug 18, 2005 #4 would it just be a matter if drilling new holes in the correct position? or modifying the holes that are there already?
T The Big Yin A well built VW Aug 18, 2005 #5 Sounds the same as the 172 needs new holes drill if thats the case
hydeyho Nike Lunar Elite's Aug 18, 2005 #6 Yep, just needs a couple of mounting holes drilling, I only did 2 in mine and it fits fine.
