MK3, Sub and Amp
Car  Homo spec mazda
Hi guys just wondering if anyone has pictures of the hole in the bulk head for the live to run through.
Thanking you
im sure theres on right in the center of the bulkhead just undo the clip on the heatsheild and you should see the gromit.
No need to undo anything mate, there is one that comes out to the passenger footwell.. have a look from the inside..
Thanks both of you awesome MK3 driving people, Im looking zippo but im just not seeing, i sees lots of thing, just none that looks big enough to get a cable through.
Last resort il use the one bio mentioned
Have attached them.
B shows the rubber grommet (the red wire is the power wire for my amp ;))
and A shows you roughly where it is (red wire again).
lol i cba going back out..
have a look in the rough area, from the engine bay, you'll see all the wires coming from it..
I stuck a thick pip through and just looked for it in the bay..
Push a thin bit of cable/wire through from the inside out, then get a hold of the wire from the engine bay.
Then tie that wire round the "loop" of the power cable that plugs into the amp. Then pull from the inside and if you've tied it tight enough and with a bit of force it'll come through.
