Roffle!!!!! Through iTunes!!
File > Add new file to library. Then Sync.
Be sure and select the correct options within iTunes, click on your iPhone which should be listed on the left of the screen.
I generally make 1 playlist with all tracks I would like on my iPhone and then select this to sync to it.
iFail.
Helps if i tick the box for sync music eh...
Next thing... ringtones/message tones...?
for ringtones download iRinger. Can make your own tune from any MP3 and it will import to Itunes as a ringtone for you, then just sync the phone again (make sure you tick the box for ringtoneslol)
Can't change text/mail sounds unless you jailbreak.
There's nothing in the App store called iRinger?
Or access Audiko on your computer, search for the ringtone you'd like, download this and then add it to iTunes. Select to sync the ringtone in the iPhone options in iTunes.
Turned it off now, I'm on 68% just now and all I've done is send a few texts ...sneeks said:3G shouldn't be draining your battery if you are in a area with good 3G coverage. My iPhone has been on for 1.5 hours and during that time I've checked email, listened to the iPod for a hour and the battery is at 97%.
3G can be turned on/off in General-Network settings.
sneeks said:That's not bad at all.
