My contacts..
AK
  M240i
Hi guys.
Just got a 3gs and i've put my sim card in it but none of my numbers are on it...?
They were all saved to the sim card :(...
Any ideas :eek:?
AK
  M240i
May aswell rename the thread...
iPhone noob & his fail questions...
:eek:
All this apple malarkeys new to me...
AK
  M240i
Doesn't work...
Is it cause they are 'acquired' songs... i.e. i never paid for them ...
They play fine on itunes tho...
  Citroen DS3 DSport
Be sure and select the correct options within iTunes, click on your iPhone which should be listed on the left of the screen.
I generally make 1 playlist with all tracks I would like on my iPhone and then select this to sync to it.
AK
  M240i
Did a playlist then when i drag it over the iphone and then over the music part it puts a red circle with a line through it :(
  Hyundai i40
you need to make a playlist in itunes
then click on the iphone icon and then go to tunes....find the playlist with the songs in
Tick the playlist and then press sync
AK
  M240i
iFail.
Helps if i tick the box for sync music eh... :eek:
Next thing... ringtones/message tones...?
  Bumder With A Buffer
I too made a playlist.."Iphone playlist" then just put stuff in there and sync that. I found that easier.
  1.8 Civic EX
iFail.
for ringtones download iRinger. Can make your own tune from any MP3 and it will import to Itunes as a ringtone for you, then just sync the phone again (make sure you tick the box for ringtones ;) lol)
Can't change text/mail sounds unless you jailbreak.
AK
  M240i
There's nothing in the App store called iRinger?
  Citroen DS3 DSport
Or access Audiko on your computer, search for the ringtone you'd like, download this and then add it to iTunes. Select to sync the ringtone in the iPhone options in iTunes.
AK
  M240i
Brilliant.. nice and simple.. cheers :D!
AK
  M240i
How do I turn 3g off? I've only been up an hour and it's already on 91% battery lol?
Also do the charging docks work with a case on, and where's the best place to get one?
Ta :)
  Citroen DS3 DSport
3G shouldn't be draining your battery if you are in a area with good 3G coverage. My iPhone has been on for 1.5 hours and during that time I've checked email, listened to the iPod for a hour and the battery is at 97%.
3G can be turned on/off in General-Network settings.
AK
  M240i
Turned it off now, I'm on 68% just now and all I've done is send a few texts ...
  Citroen DS3 DSport
Usually by 4.5 hours of usage my iPhone battery is nearly dead so your current reading is perfectly OK.
  Citroen DS3 DSport
Looks fine. All depends on what you are using the iPhone for. Browsing and video playback will obviously drain the battery far quicker.
AK
  M240i
Good stuff.
How do I stop it cropping the pictures?! It's not letting me show the whole screen when uploading with Tapatalk?
AK
  M240i
Is there a way to set up groups? i.e. text groups?
When i go into contacts and groups all it says is all contacts, all on my iphone and MACo (my work) global address list (which is imported from my e-mails being synced i think..
