Just realised your non sport but it should be roughly the same principal.
Place jack under sump with block of wood to support engine.. Undo bolt from mount to engine.. Remove 4 bolts holding mount to shell.. Lift engine using jack (be carefull) remove mount and replace in reverse. Unsure of torque settings best bet is to use a Haynes for a more detailed guide although this should help in changing.
