Need a spare key coded...
  Clio dCi65 Dynamique
Had just one key given to us when we got the car, have managed to get hold of a secondhand blip, case, & have had a blade cut to match mine, this gives me greater piece of mind if I should accidently lock my keys in the car, I can use this to manually open the door... :approve:
Ideally I want to get this coded so it will work as a normal key to remotely unlock the doors, work in the ignition etc...
Renault have said the plip chips themselves are coded for life, & I will need to buy a brand new one (£100ish) & then pay an hours labour to get it coded(£43ish)
Is this fact or fiction? Anyone got a new key done recently?
  Ktec'd 1.2 16v Sport
There is a method that is something to do with pressing and hold central locking button whilst key is in ingnition etc.(cant find it though)
But I'm pretty sure once key has been coded its done for life. You may get it to remote unlock but not start.
Been told not to try the key in the ignition as the immobiliser may have a collosal sense-of-humour-failure and lock out... Urban legend or not I'm not in a hurry to find out, lol
Tunst
  Focus ST225, Focus E
My diagnostics scanner can code keys but ur a bit far away..
  Jap Box
I also need this done myself, got the key here and an extra blade to go in there, just not got around to coding it to the car (its the infared type)
Need to ring a dealer at some point and get it done, its just finding the time to do it :(
  Clio 172 cup
i only have 1 key for my clio 172 cup.
i need a new circuit board to go in the key aswel, the button fell off the circuit board on mine and soldered it back on but still doesnt work.
im from derbyshire, were do i go the get a new circuit board to put in the key and get it programmed for the car????
  Skoda Fabia vRS
£43 to code a key is really cheap ! personally id go snatch their hand off, we charge £81.08
D
Dj Annihilation
Cost me 140 in total for the key to be cut and all programmed, i needed one as only had one with car, and spares are vital! - i thought 140 all in wasnt too bad....average i think this day an age, espesh for main dealer
  Megane 225 F1
Which dealer was that? I need a whole new spare key.
Quote from Renault, Yarnbrook -
Plip key blank(key chip internals) - £87.39
Key case - £24.80
Cut key blade - £13.28
Coding - £45
=£170.47 Net
+ £29.83 VAT
£200.30! :dapprove:
