Would strongly advise agaianst any of the makes listed on that Argos link. Having worked in electrical retail for 3 years i can assure you, you will be returning them within a few months. lol. Just spend some money on a decent one and save yourself the bother.
1 lnb = HD sky with no record facility.
Unless i start tinkering with the shared dish.
As far as I know there are only two different manufacturers making freesat HD boxes right now. Humax or the 'Bush' boxes
Freesat HD PVR boxes are out late November.
Im considering cancelling Sky too.
How did you get on with cancelling? were they arsey about it?
You can record perfectly fine with 1 feed from the LmB. I do it all the time.
Granted you can't record one channel and watch another but you can still record.
Oh and it's LNB
Yep you can, i have sky hd on a shared dish.
All you have to do is create a manual recording that last 24hrs and repeat it daily, it doesn't take up and hd space as its recording nothing on tuner number 2. You just have to delete the failed recordings on the planner from time to time.
Oh and just in case you wonder, you have to do the above because if you dont and for example you press record on say Lost, it auto defaults to tuner 2 which will have no signal. So if you do the above tuner 2 is busy so it records via tuner 1
Hope that helps
gav
The new HD EPG supports single LNB configurations as well, although it's something that Sky turn on and off over the air when you tell them rather than an option in the settings menu.
In dual mode apparently this trick does not work anymore and in single mode you completely lose Anytime. (Not sure if that's a massive loss, but I'm one of the people who does actually use it).
I believe this is so that the box can cache the EPG data overnight where it would normally grab the anytime streams.
I'm loving the new EPG, finally you can cick 'i' on a programme whilst in quickview and it gives you the info for the programme you have highlighted, not what you're watching! Hooray!
Well to bump an old thread....
I finally got the Humax Freesat box with HD and 320G HDD today.
Impressive so far and easy to use, only 2 HD channels so far but better than nothing.
Paid 275 for the box, as I said in a previous post, its cheaper than fcuking Sky+ ;-)
If you want to record then get one.
Like the HD btw, but god does it show up the ugly people. Good job im not on TV.
