For the best performance you should use new pads with new disks. You don't need though.jaggers12 said:i only changed me pads last week, do i have 2 change them again??????
You'll damage the compound of the pad.chammyman said:erm why not remove the opil coating with brake cleaner/carb cleaner/meths before burning it off when braking?
Disk arn't perfectly even thats whty pads were to the disk they won't have worn much though hence why I did say "You don't need though."rex said:Unless the pads are worn unevenly, where they will need to be replaced, but as only a week old, doubt this is the case.
Give us an avatar edde!
