new error on the 182 errrrrrrrr
  white leon cupra R
any one had this???? exhaust gas monitor warning light ..........
says in the manual if light is constant contact reno asap
just about to phone reno as there system was down earlier like always!!!
  CX-7,westfield,ix20
Mine is on all the time now since fitting my decat pipe.
If you still have your cat in place more than likely a duff lambda sensor I'd reckon.
David
  2015 ST2(MO)/CorsaLE
i have same car as you - mine came on 2 weeks ago! aa man came out just reset it! and i was on my way! then same thing happened the week after! so booked in to renault! who have fitted a new o2 sensor foc! under warrently get it booked in ;)
COMMON FAULT :(
  BMW M135i
Duff lambda/duff cat, most likely lambda. You still under warrenty? If not I can read/reset the fault code to see if it comes back.
  b/g 182, meg tourer
yep, if its a standard cat then it will be your lambada sensors playing up. same (usually) happens once a decat is fitted
I've had this happen twice since I've had the car (3 years from new) It will go out in exactly 2 days. It's a Renault.
  white leon cupra R
wow loads of reply`s carnt get throu to reno to book it in car is still under warrenty so hope fully they will sort it, goin to try and get it looked at 2morrow or friday
bhm01 how do u reset it??
you can buy a tool for 20.00 or failing that ring the aa they will do it (your under warrenty)
  white leon cupra R
reno have phoned the aa now and im waiting for them to come said they will be here at 15.00
  white leon cupra R
a man has been came early to my surprise lol the fault was a p0325 which is a knock sensor???? the aa man has never heard of this have any of you?? any after reseting the ecu the fault has gone...
hope to never return
  BMW M135i
Just suck it and see for a while basically, see if it comes back.
The way renault say in the manual its the toxic fume warning light in the manual when it isn't only sets out to confuse people, as its actually the standard OBDII MIL light (fault light). Could be a variety of things other than exhaust gas faults.
  white leon cupra R
done about 20 miles since error not yet returned ....
gotta nip to reno tomorrow to price me up on 2 of them 182 tyres so ill ask them about the knock sensor
  LY 182 FF CUPPED
are you on about EXALTO"S???.
If so I would stop of at the bank and ask the manager nicely for an extension on your overdraft.???? why?
Cos Reno will rip you off.
  172 mk2 Iceberg
anywhere else except ren. !!
I get mine from mytires.co then fit them via a local fitter whos not registered
  Renault Clio 182 Cup
Hi eveyone, was just wondering has ayone had the flashing light situation for this exhaust warning light? Ive got an 04 182 and literally just had the MOT done, ive never seen this light appear until guess when !! yep 1 day after the MOT was done by renault. Ive kept an eye on this and its only happened once more whilst sitting in traffic, i feel i should book it in asap, but i guess im just asking is it normal for this light to be inconsistent? This was measured since saturday just gone. Cheers for any help. J.
Yeah, ill check the situ, as i bought the car from renault a year ago, so out of its 3 yr warranty, but im sure i extended it. Many Thanks. J.
