right click properties then copy the URL in the 'all sizes' page
Cant do that, its some sort of flash type system instead now.
Mine still looks the same.
Can you not right click on the picture, select Properties and copy the address?
Will be changing so you cant use the old version eventually.
So far the only way i can seem to find the link is to grab the html code and the link is in that, but it is a right pain and a lot of effort.
They should have pre-coded lines to copy over like pb do.
Edit: Actually it seems i'm an idiot, if you go view all sizes, then you can still right click on the image for the address. Still think they should give pre-written code for forum use since that what a lot of members use flickr for.
