Turbo'd MX-5 MK4
Guys,
I'm starting to put a 'loose' list of components together and I'm a little out of step with things.
If I have a motherboard that has support for the following:
Memory 6 x DIMM, Max. 24 GB, DDR3 2000(O.C.)*/1600/1333/1066 Non-ECC,Un-buffered Memory
And I'm running an i7 920 D0 2.66GHz @ 1366MHz (no desire to OC)
I was looking at the following memory:
http://www.ebuyer.com/product/152641
But then for the difference in price I'd be more inclinded to go with the following:
http://www.ebuyer.com/product/158372
Question is, I presume even though I'm running the CPU @ 1366MHz bus I can ofcourse run the memory at a different speed, this MB obviously supports 1600MHz and I would assume the 1866Mhz, but aren't 100% sure?
