NEW problem in my car
Car  F4R
Hi guys,this is my new problem:
After being broken my belt in June, my car now has another problem.
The car can not accelerated to over 6100rpms in 4 gear and did not know what else to look for
The engine has been revised in a workshop and it is perfect, someone has done the same?
The car is the same as if it were limited to 6100rpms:(:(:(:(.
At 1º,2º and 3º gear the car can go over 6100rpms, but not like naturally, we note that costs pass it
Need help
Sounds like the ecu isn't seeing the coolant temp or the thermostat is stuck open. Check the wiring to the coolant temp sensor and also check that the top radiator hose gets as hot as the others!
When the coolant temp is low the ecu stops the car revving past 6200rpm
I think that's not the problem because when the coolant it's cold,the car is disconecting,and what he does now is not to be disconnected, but stays still without disconnecting
