Novice Help Needed
  Clio 2 1.2 16v
OK so I've got round to needing to top up my power steering fluid and.....where's the pump? I can't find it under my hood at all. I have a 53 plate Clio 1.2 16v.
  XC90, 330d, Trophy’s
Under the hood? Are you in America?
power steering reservoir is just to the side of the suspension turret.
as you stand looking into the engine bay, it's the turret to your right, a cream coloured tank with a black cap.
  Clio 2 1.2 16v
Thanks for the responses, So where would you top up on power steering fluid? it's started squeaking on 3/4 lock and above.
  Suzuki Ignis Sport
You don't need PS Fluid because it is electrical. The squeaking might be the rubber firewall boot, open the bonnett and look for where the steering wheel joins the steering rack. There's a rubber boot, spray some lithium grease under there. It could be that it's dried out :)
