Now blowers won't turn off!
  54 Clio 182 2.0
So I have previously had a problem with my blowers not coming on at all, this was due to the transistor in the resistor pack, which was sorted. Now i cant turn the bloody thing off!! Full blast heat, and cant turn it down or off! (luckiness it's winter) Is it the same process again?
Many Thanks!!
  Moogun B95
When the transistors blow, they either go open circuit (no fan) or short-circuit.. and your fan will work flat out. When you replace the FET, make sure its put in with new heatsink paste.. otherwise the repair wont last too long. Do you need a part number for the FET.. i'll check for you.
